#455834 03/25/21 09:38 AM
Does anyone know the lengths of the front and the rear brake pull rods. The front rods are shorter than the rears I think, but I don't know for sure. I can't find the information in any of my known books.
Any assistances is appreciated.
My Chevy is over 70 years old and still running great. I hope I keep running cuz I just turned 81 !!
Hi there
My parts book says:
The front brake pull rod is 33-5/8" long. Threaded on one end and a clevis on the other.
The rear brake pull rod is 26-9/16" long. Also threaded on one end and a clevis on the other.
Also, that appears to be an OVERALL outside dimension. NOT measured to the center of the pin hole.
Hope this helps! :-)
Ole S Olson
Yes this does more than "Helps" Thank you much !
Peter Z.
