I have a 1930 with a 1932 downdraft carburetor. The linkage that my Dad made isn't very smooth. I understand that on a 1932 block, there was a bung cast in the side of the block to facilitate the pivot point for the bell crank. I don't know where that is. Can any of you help me with dimensions so I can make a bracket to put the pivot point where it needs to be.
Thank you
The accelerator bellcrank on the 32 is directly behind the exhaust manifold/exhaust pipe flange.
Thank you...
