I used a local glass supplier/fabricator, told them the type of glass, dimensions, edge finishing, etc. and ended up costing me about $35 per window, the luxury of flat glass! If I remember correctly, the front windshield was 1/4" laminated, doors were 1/4" safety glass with a polished pencil edge finish and rear window was 3/16" safety/tempered glass.
If you are getting new seals/weather-stripping, I would recommend comparing that to the original in case you need to adjust your glass dimensions. I had to cut down my door windows ~1/8" narrower to account for the difference in the weather-stripping.
-Tyler
