Hi, My name is Robert. Im from The Netherlands. I need a chassis diagram from a Chev sedan 1930 with the measurements of the wheelbase. 1930 and 1931 is the same? I have to prove to the Dutch autorities that I have a Chev frame. Who can help me? Kind regards, Robert
There might be something in this info from the GM Heritage site. You can also pull up any year and see the differences. The 30 and 31 are not the same.
https://www.gmheritagecenter.com/do...mation-kits/Chevrolet/1930-Chevrolet.pdf
Thank you Dave. But i need also the dimensions
Robert,
Does the attached file meet your needs?
Attached PDF document
Hi Cipper, Almost. We need this diagram for a 1931 sedan.
My wheelbase is aprox 108,5 inch
Thought you had a 1930 Sedan.
With a nominal 109" wheelbase it will be either a 1931 or 1932.
See the attached file. Does this one help?
Hi Chipper, I need your diagram for a 1931 Chev. Because my wheelbase is aprox 108,5 inch
I think this is the chassis I have. But I have to prove that this chassis 108,5 inch belongs to a 1931 Chev. On your diagram I dont see the year. Correct?
Hi,
Although I do not have any expertise in the early 1930's cars, I do have some documentation that might help.
Attached are scans from my Genuine Chevrolet Parts book that covers 1929-1941.
Robert,
The drawing was done in 10-3-30, which is October 3, 1930. 1931 model year production began in October 1930.
You can also go to the website established by Bill Barker 1931chevrolet.com
which has extensive information on 1931 Chevrolets.
Thank you all for the quick info!!
The 1931 version, page 16 I believe, shows the frame and wheel base.
https://www.gmheritagecenter.com/do...mation-kits/Chevrolet/1931-Chevrolet.pdf
