Agree with Rusty, above. If it has all of the accessory brackets, orig. carb, dist., air cleaner, etc. that would add value. 1962 327" valve covers are one year
only. It it has a 2 barrel it is probably a 250hp, nothing special. If a 4 barrel, could be 275 to 300 hp, more desireable. If you know the mileage of the car
it came out of, that would be helpful in selling it if lower mileage. Also, check Craigslist in your area under Auto Parts and you might see a range of pricing
to guide you. bobalouie
