I recently had to adjust the vacuum shift on my 41 coupe.
I used a new adjuster I got from one of our major suppliers/vendors.
I had trouble getting the trunnion through the hole in the adjuster. I had to ream out the adjuster in order to get the a trunnion through it. I had several clean and even greased trunnions but none would go through the hole without the ream job.
Has anyone else had this problem?. This is the second adjuster "washer" I've had to ream out. (I keep losing them.)
I'm trying to find out if , over time, I merely got a couple bad ones or the problem is me or is there something wrong with the size of the adjuster hole. Don't want to blame the part and its source without trying to find out if the problem has happened to others.
Thanks,
Charlie
