I have the 8 tube Radio #985536 for my 1940 Chevrolet. I had it restored but didn't realize that the antenna connection is not the modern type connector so I didn't know to have it modernized. Does anyone have and adaptor or can show me how to make one? Thanks for your input.
Support The VCCA!
Just what are you referring too? As I remember I think the connector is inserted after the case is installed. If that is missing you have a problem.
I have sold out of the adaptors. I suggest you return the radio to the person that restored it and have him replace the antenna connection on the radio and that will solve your problem.
Every radio I restore I change the antennna socket if it is the old 'push and turn' type. Sometimes the customer is lucky enough to have a roof or underrunningboard antenna still on the car. In that case, I don't change the socket.
devil Agrin
Thanks a lot. DS
