#454025 02/05/21 09:38 AM
m006840 Offline OP
Looking for ball park value of a rim spreader tool. Looking at one on Craigs list says Pacific Rim Tool, For Photo: https://nh.craigslist.org/tls/d/tilton-old-pullers/7268108151.html I tried to copy the photo but no luck . As pictured all are available for $100.00 Other parts are for T & A
m006840 #454033 02/05/21 03:41 PM
I think $100 for the whole lot is a good price. The rim spreader alone goes for over that on ebay. You could research the other tools and sell them to recoup some $$.
BTW, if you right click on the photo and copy its image location, then you can post it here using the Full Editor and the insert image link icon.
Here's what the coding looks like:
Code
 [img]https://images.craigslist.org/00g0g_64Z1Jw3zH7Oz_1ck0TK_600x450.jpg[/img]
Here is the photo of the tools lot from the craigslist listing: [Linked Image from images.craigslist.org]
Rustoholic #454037 02/05/21 05:41 PM
m006840 Offline OP
Thanks for the info Dean. I'll try your suggestion for posting the photo next time I need to. I did try copy image and paste with no luck so quit there.
m006840 #454042 02/05/21 09:42 PM
The rim spreader appears to be missing one arm and would be worthless.
m006840 Offline OP
take another look. Two arms and one main hook at the crank handle end. Appears complete to me but I could be wrong.
m006840 #454044 02/05/21 11:37 PM
Looks complete with the two pivoting arms and the other retracting and extending arm operated by the crank handle.
m006840 #454059 02/06/21 06:39 PM
I usually get $50-$60 for rim spreaders. But I buy them cheap and pass them along to guys who need them (and usually didn't know such a tool existed). The tool below the rim spreader seems to be a valve spring compressor . The one in the middle top is most interesting to me. It looks like a puller but the design of the jaws is not visible. I can't tell about the one on the left.
35Mike #454065 02/06/21 09:15 PM
m006840 Offline OP
The tool on the left is a valve tool as is the lower right. The center one appears to have a lip on the outer end and is a puller of some type possibly for a bearing or bushing. I don't have a need for any of them but thought they would be good trading material or as you do pass on to someone that could use them, The owner also stated he had some 30's Chevy stuff so it may be worthwhile to checkout.
m006840 #454067 02/06/21 09:52 PM
I stand corrected. You are correct, the rim tool does look complete and useable. That makes the pile more valuable.
m006840 #454083 02/07/21 11:03 AM
Steve,
Explain the valve tool on the left to me. I like it, I just don't understand how it is used.
m006840 #454086 02/07/21 11:34 AM
m006840 Offline OP
Mike I had a friend explain it to me and I am still not sure.I did check some Utube videos and they were helpful.
m006840 #454116 02/08/21 04:37 AM
Lou Offline
I made one out of some chain and turn buckles.
m006840 #454123 02/08/21 01:23 PM
I only use the rim tool for expanding the rim after the tire change.
To get the rim out of the old tire, I just use tire irons. This method is describe really well in an article that is listed in the Technical Articles in the Members Only section off the main VCCA page.
m006840 #454147 02/09/21 01:34 AM
The door hinge pin removal tool might be a handy item. I was lucky and found the rim tool I use for $25.
