Posts: 31 |
I was thinking about changing the engine pipe on my vehicle and had thoughts about the hardware for reassembly. Brass nuts was always the way to go but I thought about stainless? Any opinions?
Chevrolet used steel nuts, ........ they will last for 70 years on a restored car.
Posts: 1,139 Likes: 75
Posts: 1,139 Likes: 75 |
Gene Is there any advantage to using brass or stainless steel when it comes time to remove them in the future? Or does dissimilar metal corrosion come into play and make it worse?
I used steel and an anti seize compound on my truck and I'm just wondering what I'm in for in the future.
Ole S Olson
Posts: 4,374 Likes: 30
Posts: 4,374 Likes: 30 |
stainless on steel would be more prone to galling on my 29 & 30 they are steel studs, brass nuts. works fine together
steel on steel or stainless on stainless also works
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I have not had a problem using brass or stainless nuts on exhaust but steel nuts often rust in the threads and dont undo easily. Tony
Posts: 656 Likes: 3
Posts: 656 Likes: 3 |
Just don't use a stainless nut on a stainless thread. You'll never get that back apart. Stainless on regular steel is fine.
Posts: 133 |
Another trick I've used in exhaust systems is to coat nuts and exposed threads with RTV (silicone). When you need to remove the nut, just peel off the RTV. The nut and threads will be rust free and come right off.
This post is guaranteed to be 100% content free! '31 Special Sedan
