Everyone, I'm having a terrible time trying to adjust my clutch on my 1940 Chevrolet. Clutch is new, Pressure plate refaced and housing rebuilt (It's the original housing), bearing from Chevs of the 40's which I will replace with an original NOS part. (I used the original bearing to make adjustments after I couldn't get the correct ones with the replacement.) Very little wear on the bottom hole of the clutch rod lever, no wear on the rod attached to the lever, clutch fork rod is as new and I have two other rods and all are the same measurement wise where the fingers attach to the release bearing. Fork ball is like new with no wear. When you go to adjust the clutch you have to go to the very end of the adjustment lever to the point the bolt is almost off the rod. At that point you still have 1 1/2" of free play with the pedal. I've searched all the threads and I can't find anything that I have done wrong to fix this. Just to throw it out there, can I adjust the ball out a bit to make up some of the slack? There must be something I'm missing. When I got the car the adjustment was at the end and the clutch was slipping badly. It was of course ruined. So somewhere in its history there was a major issue here. This is just one problem with the car. I have been able to solve everything else. (What a story about the steering box! That's for another day. Thanks for any help.
