#45288 11/21/04 12:26 PM
I just picked-up a 50 Chevy 235 De Lux from my old Aunt. I was wondering if adding MMO in with the gas on this old engine would help lube the old valves. I was reading were one person mixes in kerosene with his gasoline when he fills her up. :confused:
Satisfaction is the death of desire.
#45289 11/21/04 02:00 PM
Not a bad idea, only don't add much as it will foul the plugs. Also suggest you remove the valve cover and direct a stream of WD-40 at the base of each valve spring on the valve stem. Do this with the engine running.
Forgot to mention: Welcome Aboard!
Agrin
#45290 11/21/04 05:39 PM
Thanks for the info. I realized too late, that I placed my question in the wrong section. I am old and the mistakes are growing proportionally.
#45291 11/21/04 07:44 PM
yea, growing proportionally with thanksgiving around the corner ................
1952 Chevy - 4 Dr. Styleline DeLuxe Sedan
#45292 11/21/04 09:00 PM
....I never even noticed....
