#452505 01/05/21 11:00 AM
I need to re-attach the trim to my 1941 Chevy Master Deluxe. Is this attached with metal to metal contact and only the clips being used to hold it on? Should there be a gadget or some type of backing?
Would it be better to apply it with tape as is done on modern cars. This is a father / son drive for ice cream etc. fun car not a show car.
When I took it off there was so much surface rust it had to be pried of in areas so I never saw how it should have been done.
When I did my 41 all the trim just goes on metal to metal.
Thanks for the update on that. Was looking at how there was a rubber piece for all the lights and ornamental fender pieces and started to wonder what else I needed.
Various sections of the belt line molding originally had stamped steel retainers fastened to the body with sheet metal screws to which the molding snapped on to. These areas can be identified by small diameter holes in the body sheet metal rather than larger diameter holes which a molding clip would push in to or fastened with a nut from the back side. An example is the short section of the cowl molding and portions of the quarter panel. These retainer strips are usually missing or deteriorated beyond use. If you have them, or can find them, the results are much better than aftermarket fasteners. Mike
1941 Trim
Good luck, Mike
Mike. Make sure you have the correct clips for the trim on your '41. There are different clips for various trim. I installed the trim on my '41 metal to metal.. Good luck JIM
1941 Chevrolet Special Deluxe
5 pass. Coupe
On cover of Feb. 2002 G & D
www.rdgsons.com/n2.jpg
Yes, I do have the various sized clips for the 41 stainless, and used the correct ones on my 41. With a little careful research I have found the clips on ebay and a few parts dealers.
Thanks, Mike
Mike,
I’m looking for some clips for my 1940 Chevy PU 1/2 ton.
Do you have any clips that you are selling?
What sizes would I need for this truck.
Thanks,
Rabaut I noticed in the G&D magazine an ad for Clips only . They should have the clips you need. JIM
5 pass. Coupe
Thanks Jim, I’ll check it out.
