#452373 01/02/21 07:38 PM
RayZ Offline OP
My first post as I couldn’t find a thread that helped me.
I have a 1932 (title) but mastermstamped on firewall I’d plate so assuming it’s a 1933.
The side of engine just right of distributor stamped. 836915. Then under G 15 3 ( I think this is July of 33?)
But head is 836273(inside) then on edge driver side is stamped G-14 1
I wouldn’t think mulch about the numbers except I took the rod cover off and trying to order a new gasket and they all seem to have bolt holes on top. My cover has, 6 holes in bottom 3nacross middle, and three on top, HOWEVER my block/head. Has no holes whatsoever to screw the cover to, which makes me think it’s other than 33.
Really trying to figure this out before I start ordering parts.
Thanks, ray
Become a Member!
The head is a July 14 1931 casting. The head will work but is actually a 1931 with 18 mm spark plugs. The 1933 heads have 14 mm spark plugs, larger valves and a few other changes from 1931.
RayZ Offline OP
Many thanks that explains why they sent me the wrong plugs. Thx ray
Weren't the spark plugs 14mm in 1933? I didn't think 10mm showed up until 1941.
Ole S Olson
You are right mis-typed the size. Will correct the post.
I knew you knew :-) Just wanted to be sure RayZ did too :-)
Ole S Olson
Aging brains and dyslexic fingers don't always get it right. A second or third look can help. A critical review does wonders.
RayZ Offline OP
Thanks guys, yes that’s my problem a 31nhead in a 33 truck, everything’s a little off so will have to double check when ordering top end studs. Did find replacement plugs at Napa that fit. I’m reading .030 gap.
Ray
