Posts: 762 |
Where is a good place to get a wire harness for my 37 sedan
YnZ's Yesterdays Parts, 333 E Stuart Ave, Unit A, Redlands, CA 92374, 909 798-1498, FAX 909 335-6237.
Posts: 123 |
I really hate to disagree with 'The Moderator', but I am presently having a terrible time with a wiring harness from YnZ through "Chevs of the 40's (for my 40), due to the lack of detailed instructions. They're very general and often state "refer to diagram", and there aren't any on their one page sheet. Even called them about it and apparently, that's all there is. Just an opinion.
DocB
Posts: 11,162 |
I had one of those for my 51 belair. I sat down with their pictorial drawing? well it is kind of a drawing, and maybe the diagram they refer to is the schematic in the shop manual? and between it, my old wireing harness and the schematic in my shop manual I wrote a connection to connection sheet, useing their numbers, wire color and the schematic, layed it out on a sheet of plywood and figured it out, really when you understand their methodology it worked out fairly well. It was listed for a 1951 Chevrolet but it would also fit thru a 1954. It had a right and left monitor bulb wire, and the 51 only has a single monitor bulb. It fit well and the sockets and connectors worked very well.
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
Try:RHODE ISLAND WIRING SERVICE, INC. (401) 789-1955. The one I purchased from them for our 31 was excellent and came with instructions and color code. Duplicate of original.
See you down the BACK ROADS.
Joined VCCA June 1, 1961
Posts: 210 |
