Again, I'll preface these pictures are for a 1941 cabriolet and may not be applicable to 1938. If anyone thinks it may be better to move these pictures separate thread let me know or please do so.
![[Linked Image from vccachat.org]](https://vccachat.org/ubbthreads.php/ubb/download/Number/14735/filename/IMG_1656.JPG)
Side view of top with no snaps over the quarter panels however the rear edges of the canvas, rear window, padding, etc. are tacked to the strip mentioned earlier. After the hidem is installed, male snaps are installed across the back to secure the boot only.
The tacking strip is riveted to the body above the deck lid. Just the edge is shown in this picture.
![[Linked Image from vccachat.org]](https://vccachat.org/ubbthreads.php/ubb/download/Number/14736/filename/IMG_1660.JPG)
View showing boot snaps along the rear but no snaps over quarter panel. The boot also has the same ridged edge as the top.
![[Linked Image from vccachat.org]](https://vccachat.org/ubbthreads.php/ubb/download/Number/14738/filename/IMG_1635.JPG)
Note the chrome strips fastened to the top of the quarter panel. The strips are not tight to the body and the ridged flap in the canvas engages under them. This ridged edge is released prior to lowering the top. The three holes showing should have been filled prior to chrome plating. They were for snaps on an aftermarket top that did not have the ridged flaps. If you look close on the inside you can see the twist style fasteners holding up the rear window curtain. At this point in the installation the metal framed window had yet to be installed.
