Posts: 55 Likes: 2
Posts: 55 Likes: 2 |
Hope all is well,
I found some heat cracks on my flywheel, my mechanic said one crack is a little deep, any suggestion or where can i find one?
Also looking for a Clutch.
1936 Chevy master 2 door, 6V
Thank you
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I would first check with a machine shop to see if turning would solve the problem.
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
Resurfacing your flywheel should solve the problem. If you can't find something closer, these guys ,in Missouri , can rebuild your clutch. They are good at what they do and very reasonable with pricing.
Unique Clutch Jonesburg Mo 636 488 5801
Posts: 55 Likes: 2
Thank i will give him a call
Posts: 55 Likes: 2
do you think resurfacing "thirty thousand" off would be good to start at?
The machine shop should determine how much to remove and then also remove the same amount from the mounting surface of the pressure plate.
Posts: 55 Likes: 2
