Posts: 59 |
At sometime ,someone removed the service brake bands from this touring car. Just wondering if those available for the model T will work,I'm sure they would need some modifications but the width looks to be the same. any suggestions are welcome. I can only imagine the clutch/brake combo pedal was finally too much for someone.
1917 490, 1928 Depot Hack, 1925 Buick roadster, 1978 Vette pace car, 2002 Z06
There was a "kit" available to modify the 490 brake/clutch arrangement. I had one for my 490 but sold it with the touring.
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
I don’t believe that the T Ford brake drums are the same diameter as 490 Chev, I had some steel sheet cut to the width of the brake drum outside diameter, and rolled them , haven’t gone any further than that though,. Ray is talking about being able to have the clutch and brake pedals work independent of the emergency brake. The emergency brake can then be connected to a hand brake lever mounted on the top of the gearbox, this handbrake arrangement came in half way through 1921,
JACK
Posts: 42 |
Jack I have a set of brake drums that will to suit your car.
OK thanks , DJP . i will keep that in mind, i was taking about having made the outside brake bands. Did you get my message regarding the 1939 Horn mechanisms,?
JACK
Posts: 42 |
Hi Jack, Yes I received your message have a problem open messenger, will give you a ring.
