#450506 11/17/20 10:23 PM
DSVW Offline OP
Hi,
I have a 1954 chevy bel air original 6 cylinder. It has been converted to 12 volts.
What size battery would you recommend for this car? Cold cranking amps, etc.
My battery died on me tonight, It has been on a charger a few times over the last month. My charging system is functioning correctly.
Thanks.
DSVW #450509 11/17/20 11:30 PM
I always buy the biggest battery that will physically fit with the highest CCA rating. Gives a bit of a margin in cold weather and the battery has an easier life overall.
I just bought a 1000 CCA tonight at Costco to replace the original 550CCA in this small car. Costco has a good battery and warranty and they do not make you match the battery size you carried in. Very convenient. Measure the current battery and the space around and above it and then head to Costco with your measuring tape and notes.
DSVW #450510 11/18/20 12:16 AM
That's suspicious., disconnect the battery after the next drive and see how it is
There's no reason to need a charge unless you have some sort of parasitic load draining the battery when the car is parked.
You can check this with a mulltimeter set for high current and connected between battery + and the end of the cable, which you have taken loose.
DO NOT hit the starter, or you'll fry the meter.
A fraction of an amp of parasitic load can kill the battery over time.
If you think there is something, disconnect the battery after the next drive and see how it does in a few days.
How do you know the charging system is OK?
Full charge voltage should be about 14V, depending on temperature.
As advised, the battery should be the biggest you can fit in the tray.
WILSON
Wilson
Wilson #450515 11/18/20 10:47 AM
WILSON
I fully agree , in this case bigger is better !
hood
p.k.
1956 BEL AIR 2 DOOR HARDTOP
p.k. #450523 11/18/20 11:20 AM
The higher the CCA, the better off you are.
Jon T.
DSVW #450531 11/18/20 01:19 PM
Is there any indication how old the battery is?
I agree with the simple checks that others have suggested.
If you are just driving short trips every couple of weeks that will not allow the generator to recharge the battery adequately. As you drive watch the ammeter. The charge rate should drop back to just above 0 when the battery is close to fully charged.
Remember that as a battery ages the capacity diminishes. So fully charged new battery has a lot more stored energy than one that is 5 years old.
DSVW #450533 11/18/20 01:25 PM
Modern batteries can go bad without warning. The battery in my pickup went fully dead with no warning. I was delivering meals for the local feed the needy program, stopped by the senior center to drop off my container and returned to a dead battery. Completely dead. There was no slow cranking or other warning signs before hand.
