#450255 11/13/20 12:38 PM
BUDDO Offline OP
I Have a 1932 Chevrolet with the original 194ci straight 6. I removed the head to have a valve job done and do some other maintenance. I took it to my machine shop and they have determined that the head has some cracks. There are 2 valve ports that have very small fractures on the seats and a couple of the chambers have small fractures in the top corners leading to the spark chamber.
Have any of you run into this? I have seen that these heads are prone to cracking and it is pretty common. I have looked for a "new" head but can not locate one. Is this the end for this motor? Do I swap for something else? If I swap what direction should I go?
Just want to get your thoughts on this. I am a little defeated at the moment and looking for guidance.
As always - THANK YOU!
call "Indy Heads" in indianapolis ind. they are online. repairing cracked heads their specialty. took them a BBC for repairs recently. Very Impressive operation. mike mccagh
find a shop that is qualified and skilled at welding, as Mike noted above.
depending on the location and depth of cracks, a weld repair can be done, then machined if required.
the 29-32 heads are known to a degree for cracking.
went through this ordeal on my 29,thought it was a cracked head, but was only warped. also had a complete valve job done. and as you know finding a replacement head is no small task !!
Buddo,Lock-N-Stitch Inc.
Repair of cracked and damaged cast iron.
Crack repair tools and supplys.
I have a 1930 head with guaranteed no cracks. It has been magni fluxed 3 times by three different builders.
I don't know of anyone that is doing head welding but have seen them pinned or "stitched" as it's referred to. it's not cheap but is a good method if done properly.
Or look for a '33 head and get a set of 33 push rods which are slightly longer.
Actually steve, the guy in ma does stitching for a very fair price. Actually I found him cheap. I think his name is Frank. He’s considered the best.
I have heard of him and did speak with him at one time but have lost his contact info. so if you could send it to me I would appreciate it. Most shops I know will get around 5-6 hundred to repair two or three small cracks and then the normal rate for rebuilding so it can run around $1000. I suppose that's cheap if nothing is available.
He charged $200 to repair about a total of 4” on a block for me. I thought that was cheap compared to what we pay for things these days. Took less than two weeks too. I’ll look for his info.
Metal Stitching- Frank Casey, 508-865-6613. Phone only. Great guy.
That’s him. Does incredible work. Thanks Dave.
Much appreciated Dave . I have copied the post for future reference.
The casting and cooling technology back in that period of time was something to be desired. I had a few heads that I had attempted to get repaired. Stitching is the most effective with cast iron, especially near water jackets and valve seat areas,
