I am starting replace the old weatherstripping on the 2 doors on my 37 Chevy I bought a new kit and I installed the metal clips around the door My first question is on the does the rubber go all around the door OR do I cut the Rubber at the hinge then start it again ?? Second on the bottom of the door it has the rubber weatherstripping held on by clips but then it has End Clips it has a hole in the one end do I put a screw in that hole how does it stay in place they did not give me instructions on attaching the end piece ???
