Good evening. Trying to connect vintage siren to truck with 12 volt system. Siren ehcked out at local starter shop and it tested out at 12v, but 30 amps. To wire this up without melting wires, I would need 6 gauge wires, which are basically jumper cable size. Original wires to this siren (never worked in my possession) are about 14 gauge and the terminals to the siren are small, so I'm not seeing how this makes sense.
Am I missing a solenoid or relay in this circuit that would get me down to "normal" size wires?
No data plate on siren, so can't provide make or model, but I can post photo if that helps.
I'll hang up and listen.
