Posts: 120 |
Looks like you will be needing a radiator shell and hood. I have both the steel and aluminum shells. The hood is in great shape needing only derusting the surface rust. Problem is you are a long way off. If I can help, let me know.
Posts: 120 |
Posts: 31 |
Great project! I just picked up a 29 engine that came with my 30 sedan. Now that it is sitting in the garage I'm getting crazy ideas to do something with it. Possible something like this.
Posts: 120 |
Posts: 120 |
Posts: 120 |
Not a lot of progress has been made, but I did score some parts over the weekend. My father and I spent the day going through a barn, digging through tractor parts and junk to get a stash of 1928 Chevrolet parts. Some of the things that I found include: front/rear axles, springs, rims, ”˜28 engine, ”˜27 cylinder head, shackles, Jaxon wheel bolts, leaf spring hardware, alemite fittings, brake linkage, steering column, ”˜27 hood and more. After laying everything on the floor and talking with my dad, we’ve decided to go back again this weekend to grab some stuff that we left behind and look for even more goodies.
Posts: 3,511 Likes: 47
Posts: 3,511 Likes: 47 |
That looks like a GREAT load of goodies! Well done!
Posts: 120 |
Posts: 1,255 Likes: 10
Posts: 1,255 Likes: 10 |
The springs are 28 as well. Those rebound plates on the top of the springs were only used in 28 and 29. Look for a 27 rear end. The brakes are better in a 28, but the 27 rear end should have the 3.82/1 instead of the 4.13/1 in the heavier 28. The gears can be changed over in the 28 rear end if you are feeling ambitious. Art
Posts: 120 |
The springs are 28 as well. Those rebound plates on the top of the springs were only used in 28 and 29. Look for a 27 rear end. The brakes are better in a 28, but the 27 rear end should have the 3.82/1 instead of the 4.13/1 in the heavier 28. The gears can be changed over in the 28 rear end if you are feeling ambitious. Art Thanks for the information. I'd rather have the higher gears, so I'll have to try to find a set.
Posts: 120 |
Alright, so my dad and I made another trip to dig through that barn and managed to fill the truck again. The big score was a stripped 1928 Chevrolet frame that was hanging from the ceiling. Other goodies include a set of rims, various body bits, a whole ”˜28 rear body clip, ”˜28 cowl, a couple hoods, running boards, and a ton of miscellaneous parts and hardware. The frame is actually quite nice, with exception for the rear cross member. I think the frame laid upside down outside for a while and that cross member got Swiss cheese’d. With that said, I’ve decided to use this frame instead of the ”˜26. It is larger/stronger, has standard front brakes and I have most of the bits to put it together. We’re going to make a bunch of measurements to see if I can swap in the unit from the ”˜26 frame. If not, I guess I’ll have to make one.
Looks like the garage also had some closed car top rails and maybe other wood parts. Did you get them as well.
Posts: 120 |
Looks like the garage also had some closed car top rails and maybe other wood parts. Did you get them as well. I did not. The lady who owes the building has a 1928 sedan that her late husband was building into a street rod. Boxed frame, Mustang II front, 4-link rear; nicely done really. But all of the body bits and wood go with that car.
Posts: 120 |
If you find that you need a '28 head, I suggest you make a post in the Parts Wanted forum. I know there are many of these heads residing in member stash piles.
Looks like you are making good progress. ;-)
I have several '28 heads. They are stacked in the storage building. Also have a couple at a local machine shop that are inline to be checked for cracks.
Posts: 109 |
I've started to mock-up the '26 replacement cross member. It's not a perfect fit, but I think I can get it to fit better. Does anyone have any tips or tricks for installing rivets? If you're not dead set on using rivets, I'd actually recommend using button head bolts instead (I'd recommend using fine threaded ones as cheap insurance). They look like rivets but don't require special tools and they are particularly nice if you're frame members don't match up perfectly because you can get a lot of clamping force to pull everything together much better than rivets do: https://www.mcmaster.com/screws/rou.../finish~black-oxide/thread-size~5-16-24/If you decide to stick with rivets, I'd recommend "cold riveting" like originally done on these frames vs. "hot riveting." Occasionally you'll see people "re-buck" (tighten) frame rivets after heating them up with a torch and while this will work for a while, the rivet will loosen relatively quickly as it will not retain its original strength. -Tyler
Posts: 320 |
Hi Brian dont know if anyone answered your axel question but the simplest and best t solution is a set of chrommolly repro axels from Billy Possum, the 32 axels don't fit 28 or earlier the sun gears are different, Ray
Posts: 120 |
I am not into speedsters, but I admire your work. Looking forward to following your progress.
Hey Brian, When you start contemplating your engine rebuild, we have a couple of good references on this website on the subject. Each will take you a few cups of your favorite beverage to get through! 1. Ray Holland (aka AntiqueMechanic), a master mechanic, rebuilt a '28 Chevy engine in a series called School is in Session. This story resides in a 250 page PDF on the VCCA's web page of Technical Articles. Go to the main VCCA website and in the Members Only area, you'll find the list of Technical Articles. 2. Four years ago, I rebuilt the '28 engine in Lurch, my 1927 one ton truck (see the links below). I documented that journey here: Resurrecting a '28 4 bangerI'm enjoying your journey! Cheers, Dean
Posts: 120 |
Hey Brian, When you start contemplating your engine rebuild, we have a couple of good references on this website on the subject. Each will take you a few cups of your favorite beverage to get through! 1. Ray Holland (aka AntiqueMechanic), a master mechanic, rebuilt a '28 Chevy engine in a series called School is in Session. This story resides in a 250 page PDF on the VCCA's web page of Technical Articles. Go to the main VCCA website and in the Members Only area, you'll find the list of Technical Articles. 2. Four years ago, I rebuilt the '28 engine in Lurch, my 1927 one ton truck (see the links below). I documented that journey here: Resurrecting a '28 4 bangerI'm enjoying your journey! Cheers, Dean Thanks for the links, Dean. I'm going to prepare a binder of resources for the rebuild. The guys that I go racing with have an engine machine shop and they're going to put a couple engines together for me. I'm trying my hardest to get them to put them on their dyno for break-in and power numbers.
Hope the dyno is accurate at low horsepower.
Posts: 120 |
