I have seen members asking questions about there doors not closing properly?/ I have a 1937 Chevrolet 2door Master Deluxe . When I closed the door on the Drivers side the door does not close properly you have to push or slam it to close. If I hold the door handle and pull it up and slam the top corner of the door it closed flush. in the glove box there are 4 door pins and 4 brass color bushings doe anyone have any ideals on fixing or adjusting the door ?/
It sounds like you need to tap the old pins out and put in the new bushings and pins. That will stop the door from sagging and should close better.
You can take each hinge off the car, one at a time. This makes it possible to work on the hinge on the bench. Just remove all the bolts holding the hinge on, close the door and pull the hinge out.
