Posts: 234 Likes: 5
Posts: 234 Likes: 5 |
Have a relatively new light switch. I can barely see the gauges at night however. Bought new bulbs and they made no difference. I believe they were 3 w bulbs. Is that right? Six volt system btw.
Use #55 bulbs and not #51.
The light intencity can be adjusted by rotating the light swich knob. Are you aware of that?
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
The OEM #51 is a 1cp bulb. The #55 is a 2cp bulb. Better but still not good. Try #316 bulbs. They are almost double the #55 and will fit. They are slightly longer but will fit. I use them in my '53.
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
Gene's response raises an interesting question.
When did Chevrolet add the dash light rheostat/dimmer function to the light switch? Based on what I read in the operator's manuals the first year was 1940.
Posts: 234 Likes: 5
I'll try to find the 316s. Sounds like they will improve the situation. The rheostat shows a potential of 6v if maxed. Thanks for the tip Tiny.
I'll try to find the 316s. Sounds like they will improve the situation. The rheostat shows a potential of 6v if maxed. Thanks for the tip Tiny. You are welcome.
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
I just bought some on EBay. The stated wattage is about twice that of the 55.
I just installed my 316s that came today. Tiny that was a great tip. They make a nice difference.
Posts: 234 Likes: 5
Great news. I just received my 316s. So I'll put some in tomorrow. As they say, all of us are smarter than any one of us.
I'm happy it worked for you.
Posts: 234 Likes: 5
Installed the 316s and drove it at night, They are at least twice as bright as the #51 bulb. I can actually see all the gauges without straining. Good tip Tiny.
