Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Can the visor with rod be removed from the mounting bracket ? I removed the clamp screw but the rod will not pull out.
The Bel Air and convertible sun visor bracket comes in two pieces, the support and the pivot.....and the visor is the third part. So all should come apart..
OK Guess I'll have to try a bigger rubber hammer or prying open the slot in the bracket. Spread it slightly with a screwdriver and it came out easily
