Posts: 200 Likes: 1
Posts: 200 Likes: 1 |
I'm doing a full restoration from ground up restoration. I'm rebuilding the starter, generator and distributor. I was wondering if I should powder coat instead of spray can the bodies of the generator, starter and distributor?
Mind you these are 1927 components. I am also looking to compete in car shows later down the line.
I am also putting new remanufactured tags on with the original numbers from the original tags.
Thorpe & Sons - VCCA Member #: 515931927 Chevrolet 1-Ton Panel Delivery Truck"Wilford"Blog and Pictures
Posts: 1,894 |
I've been going through the same process for awhile. I've avoided powder coating as the finish does not look like the original finish would have and the finish thickness can cause fitment issues as powder is thick. It's fairly reasonable to do so worth considering on some parts possibly like rims or complete frames as the powder coater does all the prep work.
Paint is another issue as a rattle can spray is not the same as it was 20 or 30 years ago. The products are very inferior due to environmental changes and many paints are not chemically compatible with others so they bubble or peel immediately. It's annoying, especially when you just want to spray a few parts semi-gloss black.
You also want the ability to be able to touch up parts down the road when you damage something wrenching so you either have to use the same paint everywhere and keep spare paint for years or find a neutral product you can easily redo. For things like starters, distributors, I've been using quality ENAMEL spray cans from farm supply locations that is intended for use as implement paint. It is easy to work with but is not some weird anti rust magic secret formula catalyzed brew. They also sell large cans so you can reduce it with enamel reducer and spray it from a gun for a better finish.
Posts: 31 |
I restored a couple of tractors and went with paint. Mostly because it is easier to touch up or even redo down the road if I need to.
I'm torn now because my car was last painted 40 years ago and things need touched up. Not sure how the modern paint will act if I spray over the old.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I am curious which farm supply vendor you are using. I have a Tractor Supply store near me . For some of the small frame brackets etc I have been using Rustoleum direct to metal spray cans. I have been putting on a flat coat as a primer and then a gloss if that's the desired finish. While I would rather have a nice epoxy primer base it's a lot more work and cost to mix a small batch to spray in a gun and then have to clean the equipment. Also the Rustoleum DTM dries to the touch in about 8 minutes.
Posts: 200 Likes: 1
You also want the ability to be able to touch up parts down the road when you damage something wrenching so you either have to use the same paint everywhere and keep spare paint for years or find a neutral product you can easily redo. For things like starters, distributors, I've been using quality ENAMEL spray cans from farm supply locations that is intended for use as implement paint. It is easy to work with but is not some weird anti rust magic secret formula catalyzed brew. They also sell large cans so you can reduce it with enamel reducer and spray it from a gun for a better finish. Thank you for your thoughts on this. It gave me something to think about. The problem is that I live in good ole California and there is no good paint lol.
