The Filling Station is a part supply house located in Lebanon, Oregon, 97335 U.S.A.They are on the net
www.fillingstation.com Also worldwide FAX 541.258.6968 Tech Line: 541.256.2114 They are on Pacific Time Zone check your clock before calling.
The front support bolts pass through molded rubber, housed in a stamping that bolts to the front cross member on the under side. At the rear end of the engine, a rubber mounting is placed at each side of the clutch housing. Forged brackets in-cased in rubber are enclosed in metal housings, bolted to the rear engine support cross-member. At the rear of the transmission and overrunning clutch or free-wheel mechanism casing there is a fourth mounting consisting of a steel strap with rubber vulcanized to both upper and lower surfaces, bushings acting as spacers slightly below the rubber surfaces and a support plate below the lower rubber. This arrangement permits a limited amount of horizontal movement at the front end of the crankcase and a slight rocking at the rear end. Hope this helps you.
