videoranger,
you're right about a picture, but thanks for your description...
ok, right off the bat, we would say that the steering wheel-to-column washer is too large, as it completely covers the two horn wire holes...in fact, the wire holes in the steering wheel are so close to the shaft that the nut itself would have to be tightened in a fashion that the flats, rather than the points, would be adjacent to the holes so as to not interfere...
is the correct washer this small in diameter, or does it have two "notches" to accomodate the horn button wires?..
also, I scooped out the hardened, 60-year-old grease inside the column housing and can see a "shoulder" around the shaft about an inch down...is this the bushing you referred to, or in other words, when installed, do the horn button wires protrude about an inch past the rear of the steering hub?..
additionally, there are no visible wires exiting the steering column...this truck's been rewired at least once before our ownership...where would the original horn wires exit the housing...I'm guessing around the back of the clamp at the dashboard?..
finally, I couldn't find the bushing, but cot40's also lists a "horn button cup"...I'm assuming that I'm also missing this part...
epi
