jlw53 Offline OP
It looks like I am missing a trim piece on my cowl. Haven’t had any luck finding anything so far. Is there a piece that goes where the hole is in my pic?
Also I need to find a lens set for my cowl lights. Anyone have a pic of what the originals look like? Filling station has some but are listed for a 31-32. Will they fit a 1930?
Someone should be able to make that piece.
Jon T.
Here are the joiner pieces you need. Also picture of a 29 cowl light. The lens is the same for 29/30.
jlw53 Offline OP
Thanks for the pics. Now I know what I’m looking for.
Do you know what fastener held them on? I’m thinking a square head bolt. You wouldn’t want to sell them would you?
All I can find for the light lens are the style in this picture.
I have 29 and the cowl lights mount through the connector so these are extra for me. PM me about them. The lens you show I believe will not fit the 30 light. I don't think any repros are available. I have lens but they are part of complete 29 cowl lights. Regards.
The lens in the picture is for a 32 (maybe 33 also).
The same "T" head screw that holds the trim on is used to hold the connector piece.
jlw53 Offline OP
Thanks. I haven't has a chance to look that close at how the trim is attached.
jlw53 Offline OP
So it appears that my trim may be held on by some sort of adhesive and not the bolts. I still need to get under the dash and confirm but I can see it sticking out from the edge of the trim in spots.
Anyone have a picture of the "T" head bolt or screw that is supposed to hold the cowl trim on? I'm still not sure what I am looking for.
I have the correct trim joiner pieces now. Big thanks to Cabboy for that.
Also picked up 1 correct cowl light lens. Still need to find another.
