Wilson Offline OP
Now that I've conquered the cam bearing, my next challenge is the two little mount thingies that mount the back of the engine to the frame.
I have the hardware, but the rubber is gone.
Does anyone know a source for getting new rubber put in?
There isn't a lot of room for rubber, so I expect they are a source of trouble.
Are there other models mounts that would work on the DB?
My truck came with solid mounts, which I would like to upgrade.
Wilson
Wilson
Wilson, contact Steele Rubber. https://www.steelerubber.com/ They bonded new rubber to my motor mounts years ago.
Bill Masters
It is possible to open up the mount and slide in strips of rubber. A little heat helps to pry them open. Need a large hammer or vise or press to close them back up. I use rubber from big truck mud flap. Tough and oil and gas resistant. Far more economic than Steele.
Wilson Offline OP
That's my kind of answer!
Who was the Bill guy who lived near you, on the bayou, had a DB pickup?
Wilson
Wilson
Chipper are the mounts the same as the 32 ?
