First, I'd like to thank everyone who has given counsel as I continue the journey to getting my '41 SD back on the road...the project is coming along well! Enjoying some great father/daughter time during this project!
Here's where we stand...I'm getting fuel up to the carburetor per this thread:
https://vccachat.org/ubbthreads.php/topics/446756/1941-sd-getting-fuel-to-the-carb.html#Post446756 and will continue to monitor how that goes...the engine turns over and sounds good, but no 'sparking'...not even a gasp.
For my testing based on some threads from the various forums I have:
1. Tested the coil: 1.2 ohms on the primary winding, and 13.38K on the secondary winding. If what I'm reading is correct, the coil seems to be good...push back if you don't agree. I picked up a new NAPA coil and the measurement on the new coil is 1.5ohms on primary and 9.22K on secondary...I thought I might see higher on the new coil for the secondary winding. Note: I picked up all new electrical ignition parts from NAPA so I would have them on hand...see more below).
2. Another test I did was taking a circuit light and connecting on the negative terminal of the coil and touching the positive terminal of the coil and cranking the engine, no light! Per a youTube video, I understand I'm supposed to see the light go on and off as the engine cranks...nothing. The circuit light tester is for 6V
3. When I pull the #1 spark plug, with wire attached and ground it to the block or other metal part, and crank the engine, I get no spark...nothing...zip. I assume I am doing this test right. Note the plugs look really good and clean and gap'd to .040
When I set #1 cylinder to TDC, I see the rotor is over the #1 spark plug on the cap, so I think we are ok there. I found the timing marks on the flywheel and cleaned those off...I haven't yet determined if they line up to the pointer yet, but I'll come back to that. I was hoping to see some just basic spark coming out of the plug. I do see the rotor moving around and the points gap opening and closing...I do need to measure that gap still, but for now I am assuming it is fine.
So my plan right now is to do the following, now that I have a new coil, distributor cap, points, condenser, (the new rotor wasn't in the order, go figure, but the old one looks good, for now) is to:
Step 1. Pull the #1 plug hand rotate the engine to TDC (have to say I love the crank tool from Chevys of the '40s guys...great addition and makes it easy). My daughter helped with the 'thumb' test, feeling the air press out of #1)
Step 2. Once at TDC, make sure the rotor is over the #1 plug and I can see the timing "bb" on the flywheel. (see pics below)
Step 3. One-by-one, put in a new component, starting with the new coil until, hopefully she fires up. Here is where I'm not sure...should I swap it all out, or go one piece at a time...meaning, should I just bite the bullet and put all the new pieces in at once (and set the gap on the distributor etc.)?
What else should I look for? Are there other tests I should be doing? I still haven't checked for gas spraying into the carb, but even a healthy dose of starter fluid and/or a bit of gas down the throat isn't getting me anything...I am assuming it is all electrical ignition/timing problems at this juncture.
Below are a set of pictures of my timing marks...anything else on these symbols I should be concerned about? I only care about the "bb", correct, not the triangle or other letters "U | C"?
Thanks in advance for any additional thoughts on my plan...I'm in new mechanical territory for me right now, so I want to be well thought out.
Note: timing mark pictures...I cleaned off some minor surface rust, and then highlighted the marks with a bit of orange paint...you see the before and after, hence the slight discoloration. For some reason I don't get the "attachment manager" feature, so have to drop these links in directly.
https://www.dropbox.com/s/6ad58ppfpvtqn4r/Photo%20Aug%2025%2C%2010%2013%2012%20PM.jpg?dl=0
https://www.dropbox.com/s/yzybcr64akfpbwa/Photo%20Aug%2025%2C%2010%2020%2025%20PM.jpg?dl=0
