Posts: 49 |
I think I already know the answer to this - but how does the indicator bulb inside the 6004 turn signal switch ground? Mine has stopped working. I thought it was a bad bulb. New bulbs don't work, either. If I ground the socket to the parking brake handle it work. So how does the bulb ground? This was working but has recently stopped. Switch has not been disturbed, but I am assuming the socket grounds to the housing, which grounds to the steering column?
Paul ***** My other car is a '62 Starfire.
It grounds to the steering column.
Posts: 49 |
Thanks. And how is the column grounded - by assembly, or is there a dedicated ground wire? Trying to figure out why ground has been lost 70 years on. The car did spend some time with a fellow who "fixed" my back-up light wiring around the column. Maybe something got disturbed?
The clamp on the swtch grounds to te column so some unpainted ares on boyh are requird The columh if grounded to the frane which is a common ground area.
