#446678 08/21/20 10:47 PM
Twigs Offline OP
Like to put new tire on my 39 Master Deluxe. I believe they make radials that look like bias ply. I'm using 15" wheels. Any recommendation on tires size to use and where to buy them without taking out a mortgage.
Thank you,
Twigs
1939 Chevrolet Master Deluxe 4dr sedan
VCCA# 50190
Twigs #446679 08/21/20 11:36 PM
In bias size ans 15" wheels a 6.70X15 was used. In a radial a 2.05 is the equal. Soemuse a 2.15 but it is too much tire for a light 1939.
Both sizes are smaller in diameter than a bias 6.70 so your speedometer willl read a little fast.
Chev Nut #446680 08/21/20 11:39 PM
Twigs Offline OP
Thank you..so would I get something like 205/60-15 etc.
Thank you,
Twigs
VCCA# 50190
Twigs #446684 08/22/20 07:45 AM
60 aspect ratio is too small. I put 205/75-15s on my 53. The base tire was also 6.70x15. Although taller than the 60, the diameter of the tire with the 75 aspect ratio is still a tad smaller than the 6.70 but only makes the speedo about two MPH off. If you put 60s on your speedo will be further off.
Tiny #446689 08/22/20 10:11 AM
Twigs Offline OP
What do think about going up to 215 size of tires?
Thank you,
Twigs
VCCA# 50190
Twigs #446691 08/22/20 11:14 AM
Wider tire. More difficult to turn at low speed. The 205 is a bit over an inch wider than the 6.70 anyway. 6.70 means it's ~6.7" wide. 205mm equals a tad over 8".
Tiny #446695 08/22/20 01:06 PM
Twigs Offline OP
Ah... Thanks for the great info...
Thank you,
Twigs
VCCA# 50190
