The indicator bulb quit in my 6004 turn signal switch in the '51. Not much information in the accessory installation manual other than assembly instructions. How does the unit come apart to change the bulb? I did a forum search but didn't come up with anything. I see a screw in the back, but it looks like it might be related to the lever.
Thanks,
Paul
Paul
My other car is a '62 Starfire.
Paul, take a look at the attached photos. There is a clip inside the cover that holds the bulb near the red indicator. Mine has a 51 bulb. Good Luck.
[Linked Image from i.postimg.cc]
That helps. Thanks.
Paul
