Hey there,
I have a real problem with universal joints breaking apart. What I did so far. Gearbox completely new set up wit all NOS parts - works and shifts great, rear axle all new bearings, propeller shaft straighened, front bearing position professionally groud to meet the alignment of the rear bearings. Found that the rear axle was dislocated to right side. Propeller shaft now sideways perfectly aligns with gearbox rear end (without universal joint). Universal joint set to move free in all directions. Followed the filling st. set up instructions, used correct lubricant. After 250 miles I have a hard disbalance - would say universal joint.
Is it possible that the angle between rear axle and gearbox is too high? The leaf spings are refurbished- The distance between the rubber on to of the axle and the stop at the body is ~7,9 inch. Could this be too much? Can anybody give me some hints on how to align the rear axle correctly to the gearbox.
Currently I really don't know what to do.- Setting the car on fire could be an option
Many thanks in advance.
