ConnorV Offline OP
As the title suggests, I am wondering if anyone has a clever solution for pulling out the rear inner axle seal without destroying it? I want to locate modern neoprene seals to replace the original with. I have designed a puller for it but don't want to spend a whole day getting material and making it if someone has a tried and true method?
Also does any know of a replacement seal? I thought I had seen somebody post a replacement SKF number but my search only turned up the front seal.
Thanks!
Connor
Connor try Garry Wallace. I bought modern seals 15 tears ago from him.
He lists them for $42.00.
http://earlychevyparts.com/
Steve
Steve
ConnorV Offline OP
Thanks for the reply, I see you are in Waterbury- I drove through a couple weeks ago when I went back home to Western MA, right up Rt 8.
What I am actually looking for is the number of a modern seal that can be pressed into the old seal housing instead of the felt. I am fairly certain that I have read about people doing this, but am having a hard time finding the source. I had to replace my computer and had not backed up my bookmarked pages.
On another note, I did manage to pull the seals out with a piece of threaded rod with a washer that was the same size as the ID of the housing with the edges cut off so it fit through the hole, and a piece of 1/4 barstock spanning the outter face. the passenger side was seriously stuck, it pulled a 3/4" bend into the bar stock. The drivers pulled out very smoothly. I'll link a pic of the tool for others benefit if they find this thread.
[img]https://drive.google.com/file/d/1NakQeDUpTnXCT61yxVZGz2Xyf0yRT8SX/view?usp=sharing[/img]
If you take the seal to your local Motion Industries or other bearing supplier they should be able to measure it and then find a close lip seal replacement. If I remember it was necessary to dimple the original seal retainer to hold the replacement seal. Didn't find the seal number when I looked. I am sure it is in a file somewhere.
The seals I used in my '28 LP diff(the same size as an LM)were: Shaft size - 1.625",Housing diameter - 2.500",Width - 0.3125" Seal Type A1 Leather,which from memory were from an early series Landrover.The Australian P/No. for the seals I bought was either PR2703(Nitrile rubber),or C2703(Type A1 leather).
CJP'S 29
ConnorV Offline OP
Thank you for that info, I found the timken cross reference, p/n 473010 at the local parts supplier for $13. I'll double check the specs on my axles and housings and pick them up.
Cheers!
ConnorV Offline OP
Just wanted to update this thread and verify that the 473010 seal will work very well. I did not use them because you cannot use the original felt retainer with this seal. In order to maintain original appearances, I used a modified National 710141 seal, (41x61x8), which I did not realize had an extra sealing flap on the face, but it worked perfectly inside the felt retaining plate after trimming off the extra material. As a extra precaution I lined edges of the seal plate with a light coating of anaerobic sealer (RTV would be fine as well) and pressed the seal/retainer into the seal plate, and reset the dimples in the seal plate with a punch.
Connor
The other thing you can do is replace the axle bearings with sealed or shielded bearings vs. open bearings. When I redid the rear axle on my truck, I bought new felt seals from Gary Wallace and used shielded bearings on the axles and have not had a drop of rear axle lube make its way into the brake drums.
