#446092 08/06/20 09:37 AM
Heinz Offline OP
Hello
Can any one tell me what parts are needed to attach the vacuum assist for shifting? I was given my father in law 39 Chevy master 85. He purchased this in December of 1939. I found a NOS vacuum assist but not sure of what else is needed. I found the old one in the trunk, but just the vacuum assist. Also the repair manual not very clear to me. Thank you
Henry
Become a Member!
Heinz #446093 08/06/20 09:50 AM
The parts book shows all the parts used and they fit 1939 only. I can scan the page and email it to you.
Heinz #446097 08/06/20 12:32 PM
The steering column gearshift was new for Chevrolet in 1939. Check out the November 1938 Service News for a description of how it operates.
As Gene noted the 1939 design is a one year design. The transmission was the same "top shift lever" as the '37 and '38. Chevrolet added a rather complex mechanism that converted the column shift lever motions to the required top shift lever motions.
In 1940 Chevy introduced a true "side shift" transmission.
1939 Column Shift Parts Illustration
Chev Nut #446106 08/06/20 06:02 PM
Heinz Offline OP
If no trouble that would be a big help. He never threw away anything maybe still laying around in the garage.
Thanks Henry
