#44570 08/28/06 05:19 PM
scottb Offline OP
I'm trying to rebuild a '54 235 and have come across a stuck heat riser valve. I've been pouring PB Blaster on it with no luck in freeing it up. Any ideas? Do I need to replace the shaft and or any bushings? The plate in the manifold looks like its welded on the shaft because I don't see any screws. Getting this thing apart could be a bear.
#44571 08/28/06 06:16 PM
To free it up do not try to turn it....but rather tap the ends of the shaft back and forth.Necessary to strike the weight to the front and shaft spring end to the rear so a lead or brass hammer is best.PB Blaster is good.If this dosen't help a torch can be used to heat it up.
#44572 08/28/06 06:27 PM
I had to drop the exhaust pipe on the 52 and spray Liquid Wrench up inside, then following the advice from, the previous post began to slowly and LIGHTLY tap on the ends, after I got a little movement I then continued with the spray, and made a tool similar to a strap wrench out of a stick and some nylon strap, I used this on the weight end and again very CAREFULLY used it to turn the weighted end back and forth, after 3 days of off and on work freed it up, installed a new spring and almost 10 years later still working fine.
#44573 08/28/06 09:31 PM
Glyn has it down. That is precisely how it is done. A little coaxing with the thermal wrench can shorten the process or destroy something depending on how much heat is used.
