Bill, click on SEARCH at the top of this page. On the left side look for FORUMS TO SEARCH. Scroll down to TECHNICAL POSTWAR 1949-1954 and click on it to highlight it. At the top of the right side, look for the KEYWORD SEARCH TERMS box. Type in "bendix brakes" You have to use the quotes just like I just typed. At the bottom, click on SEARCH FORUM. You should see 21 results. Go to the fourth posting down and you are there. But also look at all the other posts that might be similar to what you are looking for. Good Luck
