need to replace the exhaust system pipe (from the muffler back),..on our 54 - 210 - 2 door post - car project. Suppose I'll take the old stuff down to the corner muffler shop and get something in aluminized steel bent to match. The car looks to have the original 2" exhaust down pipe (up front of the muffler), it still had enough meat left in it to allow me to clean it up and repaint with high temp..
Question please:
The exhaust pipe that was on this car, (from the muffler back) was all 1-3/4" OD pipe. It also was not bent on a mandrel so the bends further reduced the size of the pipe in bend areas.. I don't have a lift, so the car is sitting on jack stands, therefore I had to cut off a couple feet of the rear most straight tail pipe section to get it all past the third member and out from under the car. Initially I figured I'd just go back with the same thing (1 3/4" OD pipe at the rear) just to make things simpler, cheaper, and easier to get back in place...however, after spending a little time re-searching here on the computer, that may not be the right thing to do. I found the following muffler port in/out info listed on another forum web site, as follows:
chevy yr 41-49,.... 2" OD exhaust manifold flange, 1 - 11/16 " OD tailpipe flange
chevy yr 50-55,.... 2" OD exhaust manifold flange, 1 - 51/64 " OD tailpipe flange
If this information above is correct, (and the tailpipe OD was enlarged slightly to accommodate the extra HP for the 235/powerglide....(1 - 51/64's is 3/64 " larger than 1 3/4" )..which is awful close... ??
There also are a couple of charts currently present on the internet that show exhaust pipe sizing for engines of all sizes. The charts are laid out showing engine CID, HP max, CFM, and pipe OD size for both single and dual exhaust systems. According to these charts, anything smaller than 2 inch (single exhaust), is too small for the 235 engine - with the 2 inch pipe being adequate on some charts and not quite enough on other charts...
Any body out there had any experience using a 1 - 3/4 inch exhaust pipe, from the muffler back ? Anyone else out there removed 1- 3/4 pipe from the rear of their exhaust system and replaced with 2 inch ? Any difference ? etc...
2" is fine with me, but again (even though it's just a 1/4 inch larger OD) it still sticks in my mind that using the same diameter as what came off should make for an smoother replacement.. all that said, I'd never want to repeat someone's previous mistake, just to make things easier.....if it needs to be 2" OD minimum - we'll make it fit,..if it can be 1 3/4" and the car will never know the difference,...even better..
Hopefully some of you old time Chevy guys will see this and speak out. Your knowledge is priceless and very much appreciated.
Steve
