#445511 07/23/20 01:54 PM
Just got a 30-31 head back from the machine shop after testing and cleaning. It is going on the shelf/for sale. What can I coat it with to keep it from rusting, other than oil. Thanks
Dick
Back in the day when I restored VW's NOS jugs and cylinder heads came with a product I think called cosmoline. It was a wax based product used to prevent rust. It was removed easily with soapy hot water.
CarDC
VCCA# 52964
35 Chevy standard 3 window coupe
oooh good ole cosmoline !!
great stuff used forever, also cleans off nice and easy with brake clean wink
around here i have been using CRC SP-400 is a similar concept, sprays on wet then drys to a waxing coating. i used it when doing my 1929. anything metal got a coat. jsut a light one. especially anything that got machined. it is made for long term storage up to 2 years. and it cleans off easily and nicely with brake clean.
Cosmoline is good if you have some. Thick oil brushed or slopped on with a rag or use a spray on oil rust-proofing spray like Rust Check or Krown. The creeping effect is good. I have spare parts outside I coat this way and they don't corrode even in the weather.
