Posts: 23 |
Hello everyone...I just renewed my membership after the lapse of many years and now am "renewed" in getting my 1939 MD back on the road. I replaced my two rear wheel cylinder and the master cylinder with new quality parts. Here's the problem, my brake petal goes all the way to the floor and will not pump up. I "think" I have bled all four wheels correctly (you never know). I found out thru Google that the master cylinder needs to be bled. The demonstration videos showed more modern master cylinder applications using tubes etc. that don't seem appropriate for my "oldie". I may have missed other possible "fixes". Any help will be greatly appreciated.
charles selkirk
It is not necessary to bleed the master cylinder first but does speed up the bleeding process. Were the wheels bled in the proper sequece? Proper seqnence is left rear first, tnen left front,right rear and last the right front.
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
The bleeding sequence bleeds the longest distance from the master cylinder (MC) fluid has to travel first. second, third and then fourth. Gene has given you these fluid traveling distances by identifying the corresponding wheel cylinder locations. Straight line distances from the MC is not the same as fluid traveling distances. Best, Charlie
Posts: 23 |
Hi Gene, Thank you. How do I bleed the master cylinder?
charles selkirk
To bleed the master installl a line where the main line goes and bend th line around to fill into the master cylinder . Then fill the M/cyl with fluid and pump. This was never done until the late model cars with dual master cylinders came along. Was unheard of in 1939 or 1949 or 1959.
Posts: 23 |
charles selkirk
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
You might need to adjust the brake. If the shoes and drums are worn the pistons in the wheel cylinders might be traveling so much that they use the full volume of fluid pushed by the master cylinder without making the shoes hit the drums.
Posts: 23 |
Good idea Rusty...Thanks!
charles selkirk
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
If each wheel cylinder piston had .10” to move, the entire pedal stroke would be used up. I find that figure fascinating!
