#44502 08/24/06 11:11 AM
scottb Offline OP
Yesterday I wanted to take my '49 3600 out for a spin and noticed that the coolant in the radiator was low. I filled it with water and took off. No sooner did I get around the block and the 216 was overheating. I parked it and waited until it cooled down with the intention of limping back home. To my surprise, when I started back up, no more temperature problem. Did I create some kind of airlock that caused the thermostat to stick? I heard about drilling 3/16 holes somewhere in the thermostat. Any advice.
#44503 08/24/06 12:47 PM
It should not be necessary to drill holes in the thermostat....but for some reason the thermostat failed to open or the opening was delayed.
#44504 08/24/06 01:53 PM
The termostat will have a small air blead hole already in place. If the water level is below the thermostat and then the radiator filled to the indicated level the cooling system will still be underfilled and there will be an air bubble next to the thermostat. If you try to drive the vehicle before the liquid contacts the sensor section of the 'stat then it will not open as it should. I suspect that the cool down time solved the 'stat opening problem and when the coolant was topped off everything will be ok.
