The 1953 and 1954 steering box has needle bearings and not bushings. That along with a slightly larger steering wheel made the 1953-54 steer easier than a 1952. If you have radial tires the steering will require more effort.
In reading the shop manual I see the later steering box has a higher numerical ratio and needle bearings,the top of the box has an embossed X near the mast jacket.The box in the car has no markings and the original box that was in the car is also not marked,I had to replace the box that came with the car because if you pulled up on the steering wheel the steering shaft would pull out of the worm.My question is how do I know if I have the later box where some not marked? I tried to determine the ratio if I turn the steering rod it will go 5 1/4 turns lock to lock and the sector will go 1/4 turn.Any help would be appreciated,thanks.
