Posts: 35 |
I had a scare this weekend when I took my '49 3600 out for a ride and pulled into my driveway. When I went to back into my garage, the pitman arm broke off the steering linkage and I had a steering wheel spinning around like a little kid's toy car. Could have been disaster out on the road. I had it towed into a mechanic to look at, but I'm wondering how that could happen and what I should make sure gets done before I get behind the wheel again. It is a little unnerving to say the least.
Posts: 934 |
Wow Scott,that is very scary. I'm going to check mine when I get home. It wouldn't hurt to check it once in a while. In fact everyone should check your pitman arm for safety. We don't need any bad news to wonderful club.Thank...Oscar :eek:
OSCAR ALBRETSEN
Posts: 35 |
I just got a call from my mechanic who says that the pitman arm knuckle broke more than likely because the kingpins were too tight. I had kingpins replaced in '04 by another shop. My guy says they appear to be way too tight and the stress on the joint caused it to break. I thought kingpins were basically pressed into their bushings. How could they be too tight? I'm thinking about having everything looked at including tie rods, steering box and pitman arm linkage. Where can I find parts?
I had a pitman arm break on my car several years ago. Was caused by hitting a rut with the steering cramped to the limit of movement. I find it hard to comprehend that tight kingpins would be the problem. Kingpins are installed by fitting each pin to the bushings after installation. If installed in 04 they should have loosened up by now or you would have been complaining about stiff steering. An overall inspection is in order.
Posts: 988 |
You are supposed to ream the kingpin bushing after pressing into the knuckle bushing. Chevy has special reamer that does both upper and lower with one tool.
