Posts: 24 |
Just rebuilt everything in the car it’s has a 235 with a 2 speed powerglide and 6volt Starter but when I go to try and start it it sounds like it gets held up and stays in gauged what do I do ????
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
You're saying the starter won't disengage?
Posts: 24 |
Yes won’t disengage and does a winding sounds and gets stuck some times
I am not an expert but it sounds like the solenoid isn't returning the starter drive. If it were me I'd try a new solenoid.
Posts: 24 |
I tried 2 starters and did same thing someone told me it might need a smaller gear that they made 2 9 teeth gears one big and one small but not sure
The solenoid and starter are separate entities. If the solenoid is bad changing the starter only will do nothing. If the teeth on the starter drive don't match the teeth on the flex plate someone else will have to chime in. That's nothing I have experience with.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
The solenoid on a 51 is mounted on the starter and most shops would include that as part of a rebuild. From what I have read above I would first verify that the engine is indeed a 51 and then verify that the starter is correct with the correct drive gear. Also the ring gear should be checked for damage. Something as simple as a missing washer could cause the problem so best that a competent shop check out the starter. Would be good to know if all worked OK prior to the rebuild. If so then you need to determine what changes were made.
Posts: 24 |
Okay I will mess with all and look at everything thanks all for all the facts cus this is all new to me
Posts: 24 |
Can a 8 volt battery work in a 6volt system? Or do I have to covert
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Most (including me) on here will say leave it 6 volt. I havent seen the 8 volt setup and doubt there is a 8 volt battery available here in Aus but may well be available in the US. Tony
Posts: 435 Likes: 2
Posts: 435 Likes: 2 |
A 8 volt battery will not cure the issue, check all you battery connections and grounds and make sure you have battery cables sized for 6 volt, 00.
1936 GMC T-14 low cab. TA for 1935-37 GMC, Director of the Gulf Coast Region
Posts: 24 |
Okay will do they reason I said will it work is I feel it’s not getting enough juice to start this new engine but I’m going to try it all I’m lost with this one and all let u know what happens next
To build on what's said above, an 8 volt battery is a poor bandaid for a problem and can cause more issues than it solves.
Posts: 24 |
Posts: 24 |
One more question what kind of 6 volt battery should I have on my fresh rebuild I have one that has 700 cold crank I just got !
I'm no expert but the highest capacity that will fit the space is my goal.
Posts: 1,113 Likes: 1
Posts: 1,113 Likes: 1 |
NAPA makes a good commercial 6 volt battery. Be warned it has the larger posts however. It fits your stock battery tray. They can sell you cables that fit.
Speaking of cables, make sure you have good grounds and are using good heavy duty cables--typically 1 or 0 gage. Much fatter than normal modern cables. That'll ensure you are not losing current with smaller cables.
Rick
Posts: 24 |
If I have a wrong gas cap on the tank will that have a hard time from starting
It will not affect the starting, but could cause problems after the engine has run for a while if the cap is not vented.
