#44448 09/12/06 12:58 PM
I finally started the engine in my new to me 35 standard. Runs good but there is a tapping noise comming from behind the pushrod cover. I removed the valve cover and isolated the noise to a pushrod that sometimes moves a little to side and is smacking the pushrod cover. I adjusted the gap for that pushrod/rocker but no joy. I am able to stop the rod from moving to the side by holding a screw driver against it. Tonight I will be taking the pushrod cover off to see whats-up.
Any thoughts about what I'll find?
Gary
#44449 09/12/06 02:00 PM
You may have a bent push rod or the lifter spring retainer has popped off..When you get the push rod (tappet cover) off also check the bottom end of the push rod for wear.
#44450 09/12/06 02:44 PM
Possibly a worn follower or cam lobe.
#44451 09/12/06 05:17 PM
Thanks guys
I will let you know what I find later tonight.
What is the best place to purchase either the pushrod, retainer etc...
Gary
#44452 09/12/06 05:52 PM
Get ahold of ChevyB he has a lot of parts.
#44453 09/12/06 06:29 PM
Many years ago I had a similar problem with my '38 216. It was caused the a pushrod hitting the oil line that lubes the rocker shaft...
#44454 09/12/06 08:39 PM
OK this is what I found and what I didnt find.
What I found: One bent pushrod 0.426 # 837384
What I didnt find: 12 Valve Tappet Springs and seats 0.503 # 837321
2 Valve Tappet Spring Retainers 0.506# 837297
Now I just need to find the parts.
I will contact ChevyB to see what he has, any other ideas?
Gary
