There is a grommet listed in the Steele Rubber catalog, PN:50-0327-20, listed as:Grommet, speedometer cable through firewall (lower). Replaces factory #1321172. It has the angled 3/8" hole drilled through it like you describe. There is also another grommet listed as:Grommet, firewall, parking brake cable, has three eighths (3/8) inch angular hole through one and one fourth (1-1/4) inch diameter grommet. This also has the hole drilled at an angle. Would either of these be the same as what you are making. I have a 35 Chevy and need both, or 2. One for my speedometer cable coming up through the toeboard / firewall, and one for the electrolock cable going through the firewall. Any info would be helpful. Thanks. If the ones in the catalog aren't the ones that I need, I may be interested in 2 of yours. Thanks again, Pete V
