#444242 06/23/20 07:44 AM
Nickels Offline OP
I HAVE BOUGHT THE SIDE MOUNT SPARE TIRE BRACKET FOR MY 53 P/U, MY NEXT QUESTION IS THE CUSTOM COVER FOR THE MOUNTED TIRE. CAN ANYONE OUT THERE KNOW OF WHERE TO FIND THIS CUSTOM METAL COVER THAT SURROUNDS THE SPARE FOR SHOW .
MANY THANKS IN ADVANCE! Nickels
Glad that you joined us.
That will be a tough part to find. I do not think that was an accessory offered by Chevy. I think it was truly an aftermarket part. Do you have the correct fender with the well for the tire?
As a courtesy to the other forum users, please make sure to turn off your Caps Lock. In the world of computer communications that is interpreted as shouting at someone.
You might also want to post your request in the Stovebolt forum, That group is more focused on Chevy trucks.
I agree that you are looking for an item that appeared later and was adapted to earlier trucks. I think they first showed up when the van customizing craze came on and spares were moved from inside the van to a mount on the back making the need to dress them up a bit. Is this kind of what you are looking for? https://www.amazon.com/Tire-Covers/b?ie=UTF8&node=15706681
Nickels Offline OP
Rusty, Thanks for your info on the cap lock, will do in the future for everyone , I feel the same way on the item that this may be aftermarket. Will try the stove bolt forum as suggested.
Don Molloy/ Nickels
Greg_H #444290 06/24/20 05:00 PM
Nickels Offline OP
Greg, I will start looking also in the area of customizing vans. thanks. Don
Nickels Offline OP
Rusty, By the way what is the stovebolt forum ? Nickels
Greg_H #444309 06/25/20 07:44 AM
Nickels Offline OP
Greg, As you can see I am getting used to the system , Thanks. Nickels
Also you might check conversion van sites or in the wrecking yards. Most Ford, Chevy and GMC vans had the spare mounted
on the back door and used metal covers as an appearance item.
Nickels Offline OP
Bob, gotcha, great. Nickels
