This sounds like a replacement tank that is not exactly the same size as an original. As long as you can get the gas cap on securely, the neck is high enough. Mine is a replacement tank and the neck is between 1/4" and 1/2" above the apron. For the straps, I installed them without lock washers and tightened them securely. Then, one at a time I took the nut off and installed a lock washer. Doing it that way makes it much easier to start a nut and get sufficient length for the lock washer.
I never needed a jack to install or remove the tank although I suppose that might make it a bit easier.
I hope that you added a ground wire from the gauge to the frame. If you didn't, you'll likely need to drop the tank to add one so that the gauge reads correctly.
